Uniden Washington - No SSB Transmit
Robb
Honorary Member Silent Key
Dec 18, 2008
11,432
3,653
323
Silicon Valley CA, Storm Lake IA
Transmits/receives fine on AM.
Just no transmit on SSB.
Any particular common problem part/area?
This is the 8719 PLL version of the Washington - BTW.
:headbang
They say its finals have given out check all the diodes and little parts on the board also may have a loss solder joint , to found if you have one get a plastic end screw driver , and tap the bottom of the board while radio is on , and if you find one fix the joint .
  • @ nomadradio:
  • @ ShadowDelaware:
  • @ c316buckeye:
    no conditions in ohio
