Vx-8r Mod for air band Help
jogefo
Nov 29, 2009
3
49
When I try to restart by pressing HM/RV + MENU power on, nothing happens, the radio just turns on normally. I hear that this mod does not apply to some US versions. Any input on this? Apparently if the nod succeeds then you can tx on: 120-173.995 MHz, 220-221.995 MHz, 400-469.995 MHz, 300-576 MHz
Can I have some help on how to tx on the air band with my rx-8r; I already have the resistor mod on it. Thanks
1 Power on
2 set MODE (press and hold MENU)
3 # 21 CWID
4 turn CWID (on)
5 Push "MODE"
6 Turn DIAL to A, push "MODE"
7 Turn DIAL to H, push "MODE"
8 repeat 6-7, to type in "AH029M"
9 Push "SET" to get out of set mode
10 Power off
11 Push HM/RV + MENU power on
12 Turn Dial to choose MODE ***
13 Push Function
14 Power off
15 Power on
I tried this also, and it didn't reboot as described. I have US model too.
I did have resistor already removed for other extended Tx modification which worked fine.
and also, the list of extended TX range doesn't make much sense.
what does it mean 400-469.995 MHz plus 300-576 MHz ? Why not just write 300-576MHz? Thats is HUGE Tx capability.
cheers
It works for me, I have a Norwegian model, Vx-8E.. I can now tx on 120-173.995 MHz, 220-221.995 MHz and 300-576 MHz:D
