Just scored a free imax looking antenna, but the finish coat is looking a little long in the tooth. Anything I can do? Gel coat? Electrical tape? Thanks!
Thanks! I'll do it! Just found out it's a Shakespeare.Yes you can gel coat it or tape it. I like to paint mine with a rattle can from the Auto store. Dont use metallic paints
i agree with this. mine was done up in flat black . never seen it at night unless right under it.lolLightly sand it with 220 grit paper or steel wool (wear gloves!) and give it several coats of marine grade spar varnish. Any hardware store should carry it. It is meant to last a long time in the sun and salty environment. That's what I have used for years.
A couple coats of fiberglass resin sanding in between the coats will last a long time have done many .i agree with this. mine was done up in flat black . never seen it at night unless right under it.lol
Buy a new one?Just scored a free imax looking antenna, but the finish coat is looking a little long in the tooth. Anything I can do? Gel coat? Electrical tape? Thanks!
I have used both Marine grade Spar Urethane and spray on Plasti-dip.
The plasti-dip works good on mobile antennas.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
