.... I can guarantee if you get in to the wrong areas the FCC will be tapping on your door....
Absolutely correct
I know of one instance in which someone with a Chinese made Handy Talkie got in to the police bands and caused some major problems.
I am not sure it was stated anyone here, but it has been done and has been documented as taking place.I call BS. No one in here is that inept.
As far as the FCC rules, life threatening emergencies can warrant unauthorized transmissions by even non amateurs on amateur bands only.I know for a fact (I have first hand knowledge of it) that an Amateur used his Ht on the San Diego county Sheriffs repeater to "call for help".
The Sheriffs dispatcher told him to clear the repeater, and he re-transmitted the call for help.
He was arrested, went to trial and used the "any method of communicating in an emergency" Part 97 FCC regulation for his defense.
the judge informed him that he was not charged with a Part 97 violation.
he was found guilty of interfering with the sheriffs repeater.
Bottom line: it's not just the FCC that can (and will) pop you.
You are correct! The malcontent called for help at least once using the "Shots fired officer down" call and every cop that heard that call was in a panic, No location given so everyone was up in arms.I am not sure it was stated anyone here, but it has been done and has been documented as taking place.
Not trying to stir up strife or anything other than the proper use of licensed privileges. I can guarantee if you get in to the wrong areas the FCC will be tapping on your door. If you get into Law Enforcement frequencies you will be visited. I know of one instance in which someone with a Chinese made Handy Talkie got in to the police bands and caused some major problems.
