Wilson 5000
thetnhillbilly
107
Tennessee, U.S.A.
I have a wilson 5000 mag-mount and I want to know if I can change it to a permanent mount for the center of my trunk. I notice that a roof mount kit is sold, but didn't know if it was compatible to convert a mag-mount, or only for new installation of someone's old roof mount antenna. Can I use other parts instead of their kit, and if so what do I need? Thanks in advance.
You can rip the magnet apart and use it as a "roof mount". However, I don't recommend doing that!
The coils are the same as is the actual mount. They use the roof mount and mount it inside of a magnet. Less parts to manufacturer!
Wilson used to sell individual parts. I'm not sure if Barjan still does or not. Hook up with a competent shop on-line and have them order you just the mount, then you'll have a functional magnet, just in case!
you can use some parts off your Magmount if you really want to go that route if money is a problem. Here's a list of parts from Wilson ,they sell everything in the parts department for there antenna's (-: I think your making a great choice in changing over to a solid roof mount , better all around ground.
Wilson parts Good luck to you Hillbilly.
  • @ wavrider:
    sea que sea que,
    C'mon let me take you on a Sea Cruise! (Maybe there is someone to talk to out there?)
    Just for the Halibut.
    Seems to be dead on the radio lately. I don't know if the conditions are horrible, or more likely my weak antennas. I may head up in the mountains on Wednesday and see if reception / transmission is improved.
