Wiring a old school tweety bird into my night k eagle
radioman24
448
34
38
I have installed a tweety bird I got from a guy, and it does work when I push the red button,just not when I key the mic, any ideas?
please if your going to post a rude comment just keep it to yourself please!!
I know nothing about that mic, but the TB-1 should have 3 wires.....red, black, and white. It seems you have the white audio wire crossed up.
yes you are right and right now it only works when I push the red button, just trying to see how to get it to work on key up.
solder two more wires on to the little switch, and run one wire to the TX wire inside the mic, and the other to the shield wire inside the mic.
then the switch will be "closed" whenever you key the mic, or when you push the button.
the mic will be useless for anything other than tweety birding though, as it will make noise the whole time the mic is keyed.
if you want it to just tweet for a second, thats a new circuit you'll need to add.
LC
I tried installing a switch to make it a "key-up" effect but i couldnt get it just right, so i ended up just scrapping the switch idea and just hit the button when i keyed the mic. I like the Tweety's pot. option to lay the hammer on troublemakers.
  • @ wavrider:
    sea que sea que,
    C'mon let me take you on a Sea Cruise! (Maybe there is someone to talk to out there?)
    Just for the Halibut.
    Seems to be dead on the radio lately. I don't know if the conditions are horrible, or more likely my weak antennas. I may head up in the mountains on Wednesday and see if reception / transmission is improved.
