WSPR
ahasverus
Dec 2, 2011
68
3
18
WSPR
dear friends
My equipment
FT1200dx
Interface scu-17 (yaesu)
download drivers port7 installed
port8 installed
cat cable (transceiver - scu-17)
cable 6pin (transceiver-scu-17) (data)
settings WSPR
ON3BM
Jo10
Audio in ;usb audio codec
Audio out : usb audio codec
power dBm 20
PTT RTS
PTT com 8
cat
cat: com 8
RIG (no ft1200dx in list ) put FT2000
serial rate set to 38.400
data bits 8
stop bits 2
handshake none
Installed the software WSPR
set dial 14.095600
tx 14.095600
Receiving ;: no problem decoding :no problem
I see the lines in the map WSPR
SENDING :problem
the transceiver led transmit light up
the scu-17 leds fsk and Ptt light up
when I consult the map in WSPR tx :0
it seems to me no signal is send out
what do i wrong
thank you for help 73
on3bm
mb2963@gmail.com
(set level on scu-17 to max) use also HRD for PSK-31 :no problems
I've done a lot of wspr (although not much in the last year). It is an amazing mode that everyone should give a try, regardless of how you feel about the digital modes. I can't believe some of the contacts that mode is capable of...
  • @ Tim Chambers:
