Yaesu FT-101 Tube Question...
C
chilinvilin
Guest
I just got this Yaesu 101 with the YC-601 frequency counter. The thing lights up and receives real well but the guy I got it from says the tubes need to be replaced so I haven't transmitted on it.
I pulled the tubes out and the two final tubes (Labelled 6JS6A Toshiba) have what looks like some glass rattling around inside them. The driver tube (Labelled 12BY7A) seems fine.
Question is where can I get these tubes?
After replacing them what will be the output wattage of this unit?
Thanks in advance....
L8ter,
JP
</p>
WOW thanks Charger.... more then I hoped for. LOL
This will keep me busy for a while tonight.
Cant wait to get this rig on the air. The thing is in mint condition and begging me to transmit on it!
Thanks again,
John Phelps
</p>
Anytime my friend.
Good Luck
</p>
Hello Chillinvilin,
Most of the 101`s have 6js6c`s, the 6js6a is a older version of the tube. Your Toshiba tubes are Japan Made, if you want to use USA made tubes, you have to change C-125 from 100 Pf at 1000 VDC Mica cap, to a 10 pf 1000 VDC Mica cap. Then go ahead and neutralize the tubes as per the Manual.
I have seen new US tubes go into oscillation and destroy the tubes if the cap was not changed, and the tubes neutralized.
Here is a page with lots of good info on it
www.qsl.net/nw2m/
It includes the tune up and the info about the whole 101 series of radio`s... a must read for anyone who has a 101.
also a Instruction manual from RF parts with Schematic Diagrams is good to have too.
I have found both Japan and US NOS tube on E-bay from time to time as well and if you can`t find any 6js6c`, you can use 6lb6 tubes if the cap has been changed.
I love My 101`s!!!
Have fun
CDX 339
West Coast Operator
</p>Edited by: <A HREF=http://pub86.ezboard.com/uaudioshockwav.showPublicProfile?language=EN>AudioShockwav</A> at: 3/22/02 7:17:46 am
  • @ Tim Chambers:
