Yaesu VX-8r mic / gps cable pinout
Ham Radio Nerd
Apr 14, 2002
9,202
1,686
283
Here is the pinout information for the Yaesu VX-8r speaker/mic & gps connector on the top of the radio. The connector on the VX-8r is the same as the Yaesu FTM-10 series mobile radio. This means you can use the Yaesu CT-M11 cable to wire the connector to whatever you desire. This chart shows the pinout for the connector, the pin function, and the associated wire color for the CT-M11 cable.
<TABLE border=1><TBODY><TR><TH>Pin No.</TH><TH>CT-M11 Wire Color</TH><TH>VX-8 Series</TH></TR><TR><TD>1</TD><TD>Orange</TD><TD>MIC/PTT</TD></TR><TR><TD>2</TD><TD>Gray</TD><TD>3.3V</TD></TR><TR><TD>3</TD><TD>Brown</TD><TD>SP OUT</TD></TR><TR><TD>4</TD><TD>Green</TD><TD>GPS TXD (CONTROL)</TD></TR><TR><TD>5</TD><TD>Blue</TD><TD>GPS RXD (NMEA)</TD></TR>
<TR><TD>6</TD><TD>Red</TD><TD>GND</TD></TR><TR><TD>7</TD><TD>Black</TD><TD>SP SEL (CONTROL)</TD></TR>
</TBODY></TABLE>
The attached conenctor diagram is from the perspective of looking at the radio. If you put a 22K resistor between pins 7 and 2, the internal speaker will be disabled, which is probably what you need to do if you are going to use the cable for programming.
Goodie. Is the nmea line rs232 serial or ttl serial or low voltage serial. probably 3.3V TTL. any knowledge of the data rate? I wonder which GPS module they are using. That would explain it all.
Probable manufacturer of GPS module
I think the module is produced by Positions, Inc., a subsidiary of Chiyoda Electronic Company. Found this (probable predcesor of the unit in the Yaesu module)
http://www.cec-chiyoda.co.jp/info/GPS_Rev1.pdf which lists the GPS72(B)038 model number.
They're on the GPS 75 series, so I'll poke around and see if I can find a datasheet for the GPS72(C)042.
Happy trails.
