Is there any radio sites were you could buy a 10 meter radio and have them put the 11 meter band in it without charging you an arm and a leg? Thanks
You didn't specify any particular brand of radio.
The Magnum S-45 OmegaForce and Magnum 257 can both be switched from 10m operation to 10m and 11m operation by simply switching an internal jumper on the board inside the radio. Doesn't cost you a cent, and you can opt to switch it back yourself if you decide to sell it later on too.
The RCI radios require a special 'key' that you have to buy and attach to a point inside the radio when purchased. That will make it cost more overall.
Every RCI 2950 series radio I have ever seen had the key packaged in the same bag as the mounting hardware. The only time I have heard of someone having to buy the key separately was when buying from a sleazy dealer especially that well known "metallic" dealer in Kentucky.
If you get ripped off like that, call the coppers.![]()
Good one HY-HY.![]()
I would certainly stay away from sparkys!!!! Unless you want a crappy job done...
