Bird 43 Mod ?
Thats the first one I looked at, then came across this one, difference was the " two-position Element Range extender circuit " this is very appealing to me.
I would not put more power through an element than it is rated for no matter the compensation rate.
The PR-90 requires no ''Hot gluing'' of any parts.
I know the PR-90 requires a power source be that a 9 volt battery and or has an input socket for an external wall wart.
I assume the other is converting rf power for it's power source for it's pep function.
i used one ,loved it .
Shot at 2009-09-27
Nope, it uses 9 volts as well. I set mine up to do x1, x2 and x4, I rarely use the multiplier, but it's definitely nice to have. It also has a built in calibration circuit using the 9 volt supply. I had issues with my PR-90 and sold it.
Keep in mind (if it matters to you) that Bird specifies the regular average-reading 43 at a max error of +/- 5% of full scale. The 43P, either from the factory with the PEP circuitry or with the official Bird PEP circuitry installed aftermarket, is specified at +/- 8% of full scale for PEP measurements. (Still +/- 5% FS for average.)
That's plenty close for government work Beetle (y)
I sure hope so! I think I calibrated at least a thousand of them in the late 1960s when I worked at Puget Sound Naval Shipyard! Recalibration every 6 months, including calibrating the specific slugs with each unit. Slugs stayed with their own meter for the equipment's life cycle.
  • @ Tim Chambers:
  • @ AWP:
