Try a t2lt vertical dipole much simpler. coax is at one end, so you dont have the messy feedpoint half way up like the one in that article.
No problem using 75ohm cable if that is what you have, Yes you can run it as inverted V but the impedance will be closer to 50 ohm. Dipole high in the clear is 70 ohm anyway so you get a good match at the antenna, mismatch will be at the tx end.Still no problem getting the swr down to 1.3 or 1.5 though . have a look at the first part of my thread http://www.worldwidedx.com/threads/homebrew-t2lt-dipole-and-3el-skypper-beam.181876/ The pics show the T2lt as a vertical , horizontal and a inverted V with the ant analyzer readings. No the airchoke measurements will work as is, the difference between rg6 size and rg 58 is very small anyway.Yes, this does look very promising, however I should mention that I am using RG6QS for the coax. I am aware that it is 75ohms while the CB is 50ohms so there will be mismatch so I will have
bit higher SWR but will still be in a acceptable range. I decided to use the RG6 because I've read that while it may not be the optimal set-up, it works rather well. Plus it was on sell; $3.00 for a hundred feet.
Now....how do I figure out the length of the air choke I need to use with RG6 or will I need it at all?
Secondly, can I bend the vertical dipole in the middle and run it as an inverted V ?
I usually use Belden RG-11. Same basic coax as LMR-400 but in 75Ω and with a little smaller gauge solid copper center conductor.Update on the RG6....
I've decided to stop using the RG6. Everything except the TX worked great. I got a low SWR with nice receive, however I think it has too much loss. Makes a good dummy load though or tv cable. WIll be working with regular RG58 from now on.
The antenna situation for work hasn't been sorted out yet but I'm leaning on using two mobile fiberglass antennas mounted vertically (dipole) for the warehouse.
For work, I just got two handhelds, Midland 75-785 which for the front desk and a Realistic TRC-216 placed at the back daycare. I'm just waiting on mics so I can mount the radios. The dipole will be connected to the TRC 216 eventually. We were using FRS radios and they worked great but no body wanted to deal with recharging the batteries. I've used several different radios and none actually worked with the power hooked up, some just did not work and others had a horrible hum on TX. Now, at least the walkies can be left on so no one needs to bother with batteries. Another issue was radios breaking all the time from dogs jumping on attendants and knocking the radios off or chewing though the ear/mic cord....the list goes on.
I work with staff who don't like dealing with the radio and instead prefer to walk 100 ft to communicate. I figure once the radios are mounted, it's easy enough for anyone to simply pick up the mic and talk. But....when dealing with people anything is possible.
The renew interest into CB was really a result of people just being too lazy to fiddle with the batteries on a daily basis at work. Maybe it will peak the interest of others, I certainly hope so.
Sounds perfect; go for it!Dipole question:
I know the feed-line needs to be perpendicular to the antenna for the first several feet. In the case of a horizontal dipole, does the feed-line have to go straight down?
For example, for a dipole strung at 17', can the feed-line be routed directly to an 8' house eave as long as the angle between the antenna and feed-line is 90 degrees?
Am talking about a standard half-wave wire dipole, not an end fed.
Dipole question:
NO. PERPENDICULAR IS PERPENDICULAR
PERPENDICULAR AS FAR AS YOU CAN GO - AT LEAST TEN FEET BUT MORE MIGHT BE BETTER.
I use a Dr. Dipole 1:1 balun and some insulated wire. Just hung a dipole up this weekend. Set up horizontally. It is about 40ft in the air. Maybe a little more. Coax is LMR240, a 60ft piece. Tuned for 27.400. It works well. Even though there hasn't been much DX on 11m. I have it set up for N/S, about 8-10 degrees east of North.
With a dipole, there's little need to use a surveyor's transit and GPS compass to align things. A dipole has a broad beamwidth in two directions. 8-10 degrees, or even 20-40 degrees, is not important. Dipoles have zero gain, but they're still the basis for a LOT of antennas used from the first days of radio right up until now, because:
a. They're simple, and
b. They're cheap to make.
Could be why. It was easier than putting my Sirio vector 4K back up just to talk. I can hear all my locals out to about 8-10 miles away and am able to make contact with all of them. So it worked out well for me. The wires for the legs are 8.54ft or 102.47". And be careful when hanging it not to stretch your wiring out as it will definitely throw off the tuning of the antenna, or where there resonant frequency is!! Live and learn! Anyways. I may also hbd a second one up facing E/W as well. Anyhow, they are great antennas for a quick means of making DX contacts and also talking very locally. Orientation will have a lot to do with how well it will work locally. But I like mine setup horizontally as the floor noise is much less and I have plenty of trees to hang up in between!! Here are a couple of pics. Have since moved the ends out a little more away from the tree branches. Anyhow. It works and I can also use it for other bands as well for just receiving. Hope this might help someone that is thinking of placing one up. Easy antenna to make, and they do work well for what they are!!!
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
