102 inch whips for 10 meter vertical dipole
SailorGriz
Jun 23, 2012
2
66
If there is already a thread covering this, please direct me! I couldn't find it.
It seems to me that it should be really easy to build and mount a 10 meter vertical dipole using two 102 inch CB whip antennas. But I can't find any information on how to connect them to the coax or how to mount them to a bracket. I want to offset mount the antenna from a metal bracket pushed out from a non-metal post mounted up from the top of either my chimney or part of my roof. I'm thinking a 20 foot section of PVC pipe should work.
Any thoughts, suggestions, direction to information would be appreciated!
k9grz
I think MFJ sells a dipole mount for the whips, might look on their mighty fine page for inspiration for building.
The Francis Amazer:
http://www.neighborhoodlink.com/Glendora_Emergency_Response_Communications/pages/386525
I've seen many pics of what your wanting to do, but they escape me at present.
There are numerous ways of doing it. One of them is to simply buy one of these Simpson Strong Ties from Home Depot and use it.
Use the studs for mounting an antenna to a mirror mount on the "L" bracket. You'll need two of them. Use one with the insulating washer, and one without in each of those two holes. Put you coax on the one that has the insulating washer.
no need for 102", The set up I have here is two 5' 6" francis whips on a workman dipole mount at about 25' and it works well on 10/12/15/17 (through a tuner obviouslly)
good luck
  • @ wavrider:
    sea que sea que,
    C'mon let me take you on a Sea Cruise! (Maybe there is someone to talk to out there?)
    Just for the Halibut.
    Seems to be dead on the radio lately. I don't know if the conditions are horrible, or more likely my weak antennas. I may head up in the mountains on Wednesday and see if reception / transmission is improved.
