Built an Astroplane in an afternoon.
Some Astroplane materials for those interested.
It was put through a translator into English, so some of the reading is odd.
Nevertheless, I found it a very interesting read and it speaks to some of the points of discussion that has plagued the AP to this day.
I see some of the old points of discussion are entering into the discussion of the Top One and New Top One, too. Enjoy.
  • Astroplane1.pdf
I have the Homebrew Astroplane back up temporarily as I do repairs and upgrades to the tip-over tower. The SWR is still great, and it works a charm.
HOMERBB IS IN THE HOUSEEEEEEEEEE > great job;)
I have the homebrew AP back in the air. The fellow I sold it to for the cost of the materials in it no longer needed it. His son was the recipient of the antenna. The son moved away and was no longer using it. It was given back to me for the price of taking it off the push up pole it was on. It has been in the air through thick and thin for 2-1/2 years now between my place and his, and still registers a very good SWR in spite of being CPVC skinned with aluminum duct tape.
Reactions: Marconi and binrat
Homer the Wizard.
Just read this old thread for the first time, couldn't be more impressed. Very well done. Hope you're still 'brewin.
Reactions: HomerBB
I got to tell you homer......If i was stuck in the middle of the Sahara Desert with a broken down vehicle, and no spare parts you are the guy that is going to get the call.....
" Here is your problem, see this wire is burned up....no wire...not a problem, hand me that paper bag....ok now see if we take this pencil and cover the paper completely by drawing all over it on both sides, then roll it up like this...see the lead is conductive, now hand me that soda pop can and let me git my swiss army knife ........"
:ROFLMAO::ROFLMAO::ROFLMAO:
Couldn’t agree more, Jeff.
Wasn’t Homer in that movie, The Flight of the Phoenix, with Jimmy Stewart?
If he wasn’t, he should have been!
Now, a question about the antenna.
Has anyone tried one using copper wire inside the tubing in lieu of the aluminum tape?
I haven't but it's worth a try. Only issue that might arise is how it would influence resonance. I don't know, but I think the dimensions affect proximity of the elements to each other which may be critical.
Reactions: Riverman
HomerBB,
I have a new Targa Astroplane in the garage ready to go up. I currently run a Sirio Gainmaster with good results but want to see if the Targa will work as good or better. I replaced all the fasteners with stainless. I have 2 questions.
Will the mast lenght affect the swr/performance. The mast will be about 35-40' long.
I live on the southern end of Lake Michigan and get sustained high winds. Is there a way to secure the ring from moving under high winds. I would perfer not using string or fishing line.
Thank you,
Harry
Some like to isolate the mast at 9' below the ring, however I never did opting only to choke my feedline at that point.
As for the securing the ring I usually use zip ties, or cable ties as some call them.
Like this on the V4k ring:
