FT-950
North Texas Mudduck
245
30
38
just picked this radio up at the Hamfest in Midland texas today
hooked it up
i receive everything
transmits from 3.500.00 to 3.999.90 and on up to 21.450.00 then nothing will transmit until i
come back to 28.000.00
it only transmits from 28.000.00 up to 29.699.90
then only transmits from 50.000.00 to 54.000.00
What do i need to do to open this up
if it dont transmit it has a red flashing TX light
So it does not transmit on 160m or 12m but does on all the rest? If that is the case then I would say there is nothing to "open up" but rather that the radio has problems that need to be resolved.
This is the frist step:
WRITE DOWN ALL OF YOUR SETTINGS IN THE MENU SYSTEM ON PAPER because all of these settings will be lost after 'CPU Reset'
are these settings from factory or is this from user input
User input settings... Memories, filter widths, power level crap like that. Don't worry about that stuff. Just convert, reset then customize your settings later.
If you've never soldered jumper pads like that you can use a small 15-30 watt fine tip iron. I usually apply a little flux, heat both pads alternately, apply solder to one pad and spread it across with a toothpick. That's usually easiest for a newbie. Just don't scorch the board.
http://www.mods.dk/view.php?ArticleId=3950
BTW, you do this at your own risk.
Some of the mods includes info on accessing the menu to increase power output. I would advise against it.
A friend had a buddy of his buy a brand new 950 around a year ago. He modified it for him. The guy took it home and hooked it up to an old shitty solid state amp. He was getting down for a little bit that evening until it took a dump. Has no output.
Last I heard it was still unfixed.
    AKA- UDX122
