If this 3D plot of the GM in free space is accurate
Would it not be the case that the radiation that appears to be at an elevation of 0 degrees (afterall that is what I think Sirio is trying to tell us here.) will largely be absorbed by the ground and everything in it's way to the horizon. So whilst you have a very low "incident angle/cut in" into the F2 layer it may well be that the signal that hits the F2 will be significantly attenuated by things it has to pass through en route to the F2 across the earth surface. (relative to say 10-16 degrees which would slowly rise above attenuation causing earth based structure such as houses and buildings.)
Or does the fact it will operate above an actual earth mean the 0 degree max radiation angle will never actually occur / or be 0 degrees ?
I wonder what the model of a 5/8 wave centre fed dipole looks like in one of those snazzy antenna modelling software's you guys have? Has anyone modeled the Gain Master to see if Sirio's plots are representative of the antenna in theory or practice ?
