Hy-Gain CLR-II
To MC. Actually it was about 48' to the feed point on the SD'r and the I-10K was 40' to the feed point. The I-10K tip was still about 5-6 feet higher than the tip on the SD'r.
Lords, there are several different M 400's and they all may be different measurements and/or angles at the GP. I think the Knockoff was more to the horizontal in the angle.
the original was:
Top radiator 99"
Radials 107" each
The Hub 1-7/8"
A knockoff was:
Top radiator 98.25"
Radials 107.25"
The Hub 2.5"
Master Chief said:
lords said:
do you remember the height of the starduster antenna itself?
To the TIP, or to the FEEDPOINT?!
(sorry Marconi, I couldn't resist!) ;)
antenna only not mast MC..lol
ok thanks just wondering because mine is 550cm (18.04').
and from the top radial is 133cm(4.3') to the top of the bottom radial(2 radial vertical)and was showing a SWR of 1.3then i lowered it to 4.2' (1" difference)and now showing 1.1.but i don't know if i am messing with freq changing..as in the manual it said 1 cm up or down changes freq...
sorry for high jacking this thread.....:p
anyways putting back up the CLR on the weekend...
  • @ Tim Chambers:
  • @ wavrider:
    sea que sea que,
