mobile 10 through 12 meters
docrock
Nov 6, 2012
15
4
13
Hello, is anyone aware of a mobile antenna made specifically to tune 10 and 12 meters? I can find 10 meter mobiles and 12m mobiles but haven't found one that will tune both. Maybe a motorized screw or something of that nature.
I've never seen a 10/12 meter antenna as such. An auto/screwdriver antenna would seem a bit much for just two bands so close together. A couple of hamsticks or similar would certainly be cheaper.
Good luck.
Reactions: 3 people
Good luck.
Two ham sticks on some type of double mount might work but the "gotcha" there is the mount.
Another alternative is to use a 10 meter antenna such as a hamstick and just chance the stinger for 12 meters. It would definitely require some effort to find the right stingers and settings, but it shouldn't be impossible by any means. An antenna made specifically for 10/12 meters would basically do something of the same sort, I would think.
My predator 10k on a triple magnet mount is tuned 1.1:1 on 27.000. On 28.500 it is about 1.8:1. On 24.945 it is about 2.8:1. With my ic706mk2g, i can make MOST 10 & 12m contacts i attempt. More often then i can on 11m, i guess due to congestion. I turn back the power on the icom to show 30 watts on 12m, 10 & 11m i leave it set to 'H', which shows about 60 watts on my mobile rms meter. Is it efficient as it could be? Of course not. I already change ham sticks for 6m, 20m & 40m. If i can talk those 3 bands without having to pull over & swap antennas, i'm good :)
I've had many a ham tell me i cant do this or i'm lying. Trust me, i get out just fine on 10 & 12 like this.
get a antenna tuner and whip antenna...
Why didn't I think of saying this. I ran this setup before I acquired my screwdriver antenna. I used a 17 meter HamStick with my LDG tuner and ran 10,15,17 and 20 with it. I choose 17 because it was near the middle of those bands, little long for some and little short for others. For 10/12 just use a 12 meter HS, it will be long on 10 but better long then short (thats what she said).
  • @ Tim Chambers:
