NMO or SO239?
Discussion in 'Amateur Radio Antennas' started by Turbo T, Aug 18, 2011.
  1. Turbo T
    Turbo T
    Expand Collapse
    Certified CB Rambo
    Feb 2, 2011
    923
    89
    On 2 meter/70 centimeter dual band mobile amateur radio antennas that have a coil in the base, do they make any that are SO239 mount? Or are they all NMO mount? I've yet to see an SO239 mount 2 M/70 CM antenna.
    Thanks in advance.
  2. Moleculo
    Expand Collapse
    Administrator
    Staff Member
    Apr 14, 2002
    8,796
    780
    Yep, they sure do and I have several in use. I have this Comet SBB-5, which is a decent basic antenna and also this Comet CA-2x4SR, which is a really nice broadbanded antenna.
  3. Turbo T
    Turbo T
    Expand Collapse
    Certified CB Rambo
    Feb 2, 2011
    923
    89
    Thanks...would you say the CA-2X4SR is the better antenna?
  4. Captain Kilowatt
    Captain Kilowatt
    Expand Collapse
    Professional Amateur
    Staff Member
    Apr 6, 2005
    13,680
    4,911
    I also have the Comet CA-2x4SR antenna with the SO-239 mount and will agree it works quite well. I have had it for over 10 years and it has never failed me yet. I really like the fact it is quite broad banded. It easily works the provincial Emergency Measures Organisation's SAR repeaters with their 143/149 MHz split.
  5. eagle1911
    eagle1911
    Expand Collapse
    Jan 21, 2011
    328
    12
    I also have an SBB-5 from Comet.. love it! Great performance, low SWR, strong and solid construction. My favorite thing about the SBB-5 as opposed to many other dual-band mobile antennas is it's subtlety. It's painted flat black from top to bottom, and it's shaped like an oversized (38") old style cellular phone antenna. It's not big and gaudy, but it still performs excellently.
  6. Turbo T
    Turbo T
    Expand Collapse
    Certified CB Rambo
    Feb 2, 2011
    923
    89
    Hey what kind of SO239 mount do you have? I'm looking for a roof mount type.
  7. Captain Kilowatt
    Captain Kilowatt
    Expand Collapse
    Staff Member
    Apr 6, 2005
    13,680
    4,911
    I'm using this one. Diamond® Antenna ~ K400C Trunk/Hatchback Mount on the rear door of my Ford Escape. I also use the K400-3/8 on the rear door for an HF antenna with a 3/8-24 stud mount.
  8. Moleculo
    Expand Collapse
    Administrator
    Staff Member
    Apr 14, 2002
    8,796
    780
    I use something like this one: Diamond® Antenna ~ C101 Cable Assembly, although the one I use has different coax.
Share This Page
