As a note of interest,when the radio is turned on it will have four modes...blank,AM,USB and LSB.Initially it comes on in the blank state where there is no TX or RX.Pressing the mode switch will give you the active modes.
The NB button changes the bands,all are lettered in the display except for the CB band.Full coverage of all bands is not possible.Adjusting the VCO coil (T8) will give specific bands coverage.If you tune it for 25 Mhz ops you will lose the top bands and vice versa.I recommend adjusting it to cover your operating needs.
RV10:AM power adjust,RV6:ALC adjust.
Recieve section will need realigning for 10 meter operation . . ."
Seems that is somewhat selective, as the VCO voltage will need to be biased twards either one part of the band width or the other. This may be remedied by using a resistor and a switch so that it can do both upper and lower band width.
Just a thought . . .
