Thanks ExitThirteen, I'll make a note of what you said and pass it on to my tech bro !Yep, that info is correct. However, the person doing the mod has to be extremely careful lifting the pins, very small, fragile pins. The radio must not be plugged in or powered on, and the soldering iron used should only be 10-15 watts.
~Cheers~
73's Take it Easy your way... Retro
