TYT TH-UV3r 2m/440 also does 220!
Discussion in 'Ham Equipment' started by Moleculo, Apr 12, 2013.
  1. Moleculo
    Expand Collapse
    Administrator
    Staff Member
    Apr 14, 2002
    8,796
    780
    About a week ago, Brick O'Lore alerted me to the fact that many people have discovered that the little TYT TH-UV3r can do 220Mhz in addition to the standard 2m/440. Enabling this feature requires the use of the programming cable and software and is simply enabled by checking the 220 band in the setup menu and entering the desired range:
    [​IMG]
    I tested this tonight and it worked! Unfortunately my battery was nearly dead so I couldn't give the radio a good power test, but I'll post that info tomorrow.
    This is cool - one of my favorite little radios now does 144/220/440 mhz!
  2. w9cll
    w9cll
    Expand Collapse
    Jan 19, 2013
    2,508
    1,178
    I would love to know the power out on 220? I am guessing that it's fairly low on 220.
  3. towerdog
    towerdog
    Expand Collapse
    one-niner-seven
    Nov 18, 2009
    607
    67
    you might want to keep what revision of the UV3R you got under wraps. Back when I was shopping for an HT I was reading up on the UV3R and found out it could display freq in 1.25cm but no TX or RX, and read another report where it would TX but somewhere around 5mW!
    I am not the least surprised they would make one radio for all and then disable either 220 or 440 depending on which model it was sold as. Once the word gets out I would expect vendors to begin marketing such UV3R as a tri-band and doubling the price.
  4. North Texas Mudduck
    North Texas Mudduck
    Expand Collapse
    Apr 5, 2005
    246
    30
    my Baofeng uv5R has the 220 capability
  5. Moleculo
    Expand Collapse
    Administrator
    Staff Member
    Apr 14, 2002
    8,796
    780
    I finally had time to test out the power output after the battery charged. It does the same output on 220 as it does on 144 and 440. My radio does a little over 1 watt on 220 and 440 and about 1.5 watt on 144 with a fully charged battery.
  6. Mudfoot
    Mudfoot
    Expand Collapse
    Jun 17, 2009
    8,037
    2,451
    That's a respectable output.
  7. Zagadka
    Zagadka
    Expand Collapse
    Feb 29, 2012
    37
    4
    Thanks for the report. Could change my view on which super-cheap handheld to buy.
  8. desync0
    desync0
    Expand Collapse
    Nov 29, 2010
    57
    8
    How did you enable 220?
  9. Mudfoot
    Mudfoot
    Expand Collapse
    Jun 17, 2009
    8,037
    2,451
    Ditto
  10. mr_fx
    mr_fx
    Expand Collapse
    Oct 8, 2011
    1,537
    167
    seems this is the case with most of the chingchongtalkies... my buddy used this trick on his wousong, or how ever you spell it.
  11. Moleculo
    Expand Collapse
    Administrator
    Staff Member
    Apr 14, 2002
    8,796
    780
    It's always through the software and the programming cable.
  12. mr_fx
    mr_fx
    Expand Collapse
    Oct 8, 2011
    1,537
    167
    I think he wants a play by play
  13. desync0
    desync0
    Expand Collapse
    Nov 29, 2010
    57
    8
    I figured that much, wanted to know what software he used.
  14. desync0
    desync0
    Expand Collapse
    Nov 29, 2010
    57
    8
    Found it, unfortunately my firmware is too old.
    Brick O'Lore: Baofeng UV-5R: Tri-band For those with uv5r's that want to check it out.
  15. w9cll
    w9cll
    Expand Collapse
    Jan 19, 2013
    2,508
    1,178
    OK sold me
Share This Page
