more questions about the Ameritron 811H and other AMPS
Snake Eyes
Oct 24, 2007
99
Been reading the various threads about using these amps on AM. Well, if i am driving one of these units with 20 watts on AM, what can I expect in terms of tube life and overall performance (11 meter plus 160m-10m)?
Also, driving one of these with 80 watts on SSB, what might I expect there?
And as a newbie here, please explain some things about dead key and swing. I haven't a great idea of what all that means.
Other than that, the only other question I have is... if you wouldn't necessarily buy an Ameritron 811H for AM/SSB operation, what could you suggest in its place?
Any experiences with the 811H amps (and possible substitutions) are most welcome!
My budget is $1k (gotta love them credit cards), and anything capable of 11 meter operation is a must (everything else is an option).
Many Thanks!!!
73's.
Snake Eyes
I would look at ebay you may find one with a expanded freq mod done already 811A Ameritron I dont use my Ameritron or Yaesu Amps on AM its rough on those and some dont do much more than an HF radio out in the end result.
on a solid 220v line with 80 watts ssb in i would expect to see close to 700-750 watts out, with 30 watts in on am 500-550 watts would be my guess using a real meter. you generally need about 100 watt input drive to see peak power output.
there really easy to convert for 10m use, just clip the green wire. if you wanted one already done you can order the standard 811 "X" as long as you have a valid ticket. ameritron will also fax you instructions on the 10m restoration mod if you fax them a copy of your ticket. like i said its just a wire.
if you put a dosy on it i would imagine 1300-1500 am and 1900 or so ssb lol.
if you could find an older sb220 that has good tubes, and has has some updates done to it you would see more power for the same or less cash. 1600-1800 on ssb and close to 1200 or so am could be obtained with the right drive.
sb220 running on 220v and if you drive it with 100 watts in you have that sucker for 100's of years :) I drive mine with 100 swinging 160 for a nice blast...
the only thing i found out on this linear is the tuning knob is touchy
but take your time and you don't have to worry about tuning it each day ,unless you surf and talk a lot of channels on 11meter...
Snake Eyes,
Most, if not all commercially made amplifiers are geared toward SSB type operations, not AM. So, be careful of how you think of the stated power outputs. For the AL-811H, consider operating AM as it states for FM (another 100% duty cycle type emission). Which basically means expect about half of the 'full output' power at best, and watch the grid and plate current readings! 'Pushing' more than the stated amounts doesn't do any good for very long, and gets very expensive very fast.
If you really want to run high power on AM the first name that comes to mind is 'Harris'. There are a bunch of other name brands too. One word of warning! Sit down before checking prices, or at least sweep the floor so you won't get too dirty when you do...
BOOTY MONSTER said:
manual for the 811 . http://www.ameritron.com/man/pdf/AL-800.pdf
manual for the 811H . http://www.ameritron.com/man/pdf/AL-811H.pdf
cutting a lil gree wire in the back enables 10/11 meters . i believe a PTT switch is needed for am use .
You need a key line for this and just about any other commercial ham amplifier. They don't key on RF; the transceiver keys a relay in the amplifier. Make sure the transceiver can handle the current and voltage the amplifier requires.
what hes trying to say is the commercial amatuer amplifiers need an exciter or relay to excite (key) the amp or its usless. I know that people make switches or (foot peddles) to press to key these Ive never actually seen one but IO know they can be made.
I've now decided to go with an export radio for local talking. It would seem that one of the exports like the Connex 4300-300 (for instance), might do the trick since I enjoy mostly AM communications.
Please check out the thread if you have any information that may be of help to me or someone else.
73, Snake Eyes
BOOTY MONSTER said:
whats the difference between a "key line" and a PTT/push to talk switch ?
http://www.heilsound.com/amateur/products/index.htm#accessories
A typical PTT switch keys the transmitter, like the PTT switch on the microphone. It doesn't do anything to the amplifier. A key line connects between the transmitter and the amplifier to handle that function. Until very recently, HF amplifiers that rely on RF sensing could not be certified for amateur use.
The Heil footswitch shown on Booty's link actually contains two microswitches, one, which closes first, keys the amplifier, so it's ready to handle what the transmitter sends it. Then, just milliseconds later, the second switch closes, keying the transmitter. It's a good arrangement; I use one myself.
