Video Of My Hi-Fi CB.
Look around the net, there maybe caps you can change out to help out that radio or ask GoldFinger
I would then add a eq to your audio chain then a compressor
Thanks for the input....I don't open em up and tweak em...don't know what I am doing....just ruin a good radio.
I don't know if this is true...but I heard some of the older cobra mobiles were broad banded?
What is these guys secret?
w5udx voodoo - YouTube
Take a look at that voodoo forum and see what those dudes run... some of them spend big time bucks to get that VooDoo audio sound.
Take a look at my signature line and thats what I run..........
Yeah.....deep pockets.:blink:
Is there any way that you can post some close up pics of your radio and all the equipment in your sig line....I don't even know what some of it is?
I don't even know where to look for a broad banded cb....or how to know for sure it is....I have a 148gtl in my closet...but its not working.
Ask your local tech or theres some online that can mod your radio to pass wideband audio.
Here's a link to my setup but I since added more to the audio chain, Way more......lol, but this is how I started
My HiFi Setup - YouTube
Pm me
ANS: Money
Expensive tube preamp, compressor, noise gate, FX processor, parametric EQ, and a Ham radio if you must know.
Doesn't mean you can't get 90% of what they do at a fraction of the cost. I do it every day and I didn't spend that much. If you don't know how to use use sound gear; then concentrate on making what you have work to its fullest. For one - don't over-compensate the use of the bass/treble controls on the mixer. If the radio has a narrow TX bandwidth - it won't make a real difference. But you have probably noticed this by now.
Like I told you a while back, they don't use mixers for one. They use a dedicated mic preamp.
The REAL secret in a hifi TX is having a radio that can TX wide to begin with. There are more shops all of time catering mods to customers for broadbanding the RX - not so much for TX. But most CB's TX filters will go as wide as 3.3khz with the standard 2.8khz filters. Just because any filter really doesn't shut off until a certain point beyond 2.8khz.
I have that 'bass master' sound using a radio that has 4.0khz wide TX radio, a mic preamp, and a condenser mic much like you have now. If you change the X bandwidth of your radio, that will have the most positive change.
Is there a difference between a dedicated mic preamp and a mixer? Yes; the dedicated preamp are a higher grade pf preamp. You are paying for things you don't need in the mixer and get a preamp that is doing what it does best - concentrating on clean audio for a single mic.
Congrats on making it work.
Bet you feel a bit of satisfaction from DIY . . .
Reactions: 2 people
ANS: Money
I wanted that preamp but it was a little more than I could afford....I got the 802 for $49 shipped...its pretty stout...I am afraid to turn it up anymore than a flat setting.....it makes that Texas ranger swing from 2 watts to 30 peak watts...I am afraid it might blow the sob up.:D
How do I find out what my radios bandwidth is?
Cool...I wanna sound like "Bass master" too.:w00t:
Not trying to advertise another forum, but you can find alot of useful info over at the VooDoo forum
  • @ nfsus:
    RFactive has left the room.
