Retevis is giving away THREE radios for their 16th Anniversary! Click Here to enter!
The 2SA1012 is located right by the socket where you plug in your 12 volt source, on the back of the radio. It should look similar to a 2SA473, but labelled A1012.
Yes it is marked but TR44 is not marked TR42,43, and 45 are all right there. Guess thats why I was having trouble finding it. I really appreciate the help.
The GE69A is the same thing as a 2SA1012. That's the part that could be suspect. Remove that GE69A and replace with a 2SA1012, NTE153, ECG153, TIP30, or a TIP62. Any of those will work for replacements. Good luck!
Might try pulling TR-43/2SB525C and test it with the diode test function of your DVM. Had a similar problem on one radio I worked on awhile back. Using a schematic can help; just follow the path . . .
Pulled the Sb525 out and if I am testing it right it shows bad, so where is the best place to get one or the substitutes of 2sb809,bc327,bc328,bc666,bc638?
Dont really want to make a $25 order or deal with the ebay clowns for a $2 part.
