are you able to find the pc385 on the sight alright.
For AM modulation, you can clip R104, this is your AMC. It's located right next to TR33. That will bump AM modulation only. For SSB, you adjust VR7, that is your SSB ALC.
Hope this helps!
~Cheers~
the resister change is if you are looking at the mods page. look at the alignment page , you asked how to adjust it. the sight has mods and alignments for the radio
First off . . . What kind of watt meter are you using . . . Is it a Dosy or a real meter that can read peak watts?
If you want to see more watts out of the radio, the first thing I would do is check the bias settings on the driver and final and then peak the four transmit coils in SSB mode/ch 20.
I would do that before getting too much modulation by clipping stuff. These radios can easily exceed 100% modulation anyway.
I was using my Dosy TC....I also have a Daiwa 801....but it seems not to read pep to well.
you need to align the TX as Robb said to get the radio putting out. then you can look at the mods.
But if it has not been tampered with....why would it need aligned?
Unless your thinking...better to be sure its correctly aligned....I will do an alignment on it.![]()
