Really?Jonbah,
I got the Telescoping mast for a local CB shop in San Leandro Ca, I am sure he can tell you where to get on, they range from 30', 40',50' 60' and up if you are interested I can give you his number.
Yes I just decided to use a mast instead of Pipe, alot safer to put up then the pipe, I mounted it the antenna added guy wires then extended it up, works great!
Thanks again for all the advice
Jerry
From what I've saw of those telescope mast, I don't see how there safe, because the pipe looks like it would be floppy in the air, thats why I always used steel pipe for my mast pipe..
That's what guy wires are for. You need several sets I knew they put those rings on the mast for a reason...lol
KNEW they put those rings on there for a reason. ..lol
Guess what those rings are called. GUY rings. LOL
Gee, I didn't know guys put rings on their poles![]()
