How do you guys ground your coax in the mobile using a puck mount and backing plate? Do you ground the coax to the backing plate or between the backing plate and roof (direct roof connection)
Im grounded to the plate but looking at it, i was thinking the ground going thru the plate then capacitivly grounding to the roof cant be as good as a direct connection to the roof. So i took out my vom and like i thought, there is resistance between the two. I got a 1.2 ohm reading. What are your thoughts and why? oh yea, YES i took all the paint and primer off the whole square on the roof so it is raw metal to metal contact
