Anytone AT-779uv
9C1Driver
Sr. Member
Aug 13, 2008
4,267
2,260
273
Just picked up one of these for some local MURS talking. Seems like a great little radio. First night of talking went well. Looks like it also has a GMRS mode. Even if I need to run two antennas in my attic on a switch should be fun.
hey there. i'm looking at this radio for the 2m/70cm Amateur bands. (studying for my extra) looks simple for MARS mod to include GMRS/FRS/MURS. per channel spacing, power etc. for life or death emergencies only of course.
question. i can't find a manual for it online. can you tell me how the scanning works? can you select/omit channels from scanning through the front of the radio? without a computer in other words. i hear the scanning is on the slow side.
i was looking at the AT-778UV, but that model has an encoder knob instead of a volume potentiometer(?). even though you can change the AT-778UV's knob default from channel to volume. also the AT-779UV's mic looks more ergonomic like my AT-5555n II with the up and down buttons on top. :D
thanks and 73
/max
Scanning on the 779UV is a tad quirky since you can only initiate scanning from the microphone keypad. You must press the ‘F‘ key and the ‘4/scan’ key in order to start scanning. Kind of inconvenient in a mobile setting. There is no way to start/stop scanning from the radio itself.
You can lock out a channel, but again, it is done through the mic keypad by pressing the ’F’ key and then the ‘3/Skip’ key.
However, when you are scanning and want to skip a channel by starting the sequence of ‘F then 3’, the radio will return to the channel it started on, not the current busy channel, so you must pay attention to the channel you would like to lock out.
So yes, you can add or remove channels from the scan function via the mic keypad.
ISSUING A CORRECTION
I need to correct one of my comments above. In doing some recent programming changes to my AT-779UV, I found a setting in the “Information Of Scanning Channel” menu that will allow the radio to stop and remain on a busy channel during scanning.
The selection is listed as “Revert Channel” and I set it to “Last Called”. Now, when scanning and the radio comes upon a busy channel, you can hit any key on the microphone keypad and the radio will stop scanning and remain on that active channel, rather than reverting to the channel it started scanning from (otherwise known as “Selected” in that same menu).
I could blame my error on the Chinglish often found in Chinese radios, but I never even bothered to RTFM, so I will take the hit on this one.
Hi I recently purchased a 779uv can it be programmed to run both gmrs murs and maybe possibly pmr446? I tried with chirp and anytone software can't get it use murs or pmr446 with chirp bit won't even attempt to program anything but gmrs anybody have this issue nor know what to do ? Thank you
There are several unlock options, make sure you have it set to what you want first. Here is a better video below.
Thank you I set the frequency range after power of and on got all my GMRS/FRS REPEATERS MURS AND PMR446 programed and working. Actually worked better using Chirp
I have another mobile on the way hope it works just as well Inhave my handhelds baobeng uv5rm and uv5r mini all programed the same should work out great..
Reactions: 9C1Driver
