(Solved) Clarifier Mod help needed for Sears Roadtalker (Slant Face) SSB 934.38270700
doffo
Sr. Member
Oct 14, 2012
698
639
103
Hello,
I finally brought out the good ol Slant Face Roadtalker SSB radio. I honestly forgot when i did the clarifier mod to it. (Must have been a few years ago.). I did open it back up and seen that I already moved the wires and soldered them to the places they needed to go.
***Purple wire is connected on the R303 on the side where it needs to be in with D301 (banded)
***Green wire connected to where the red wire is (8V source) The black wire coming off the Fine Tune is just going to a nearby ground.
While the radio is on, stations come in great and the Fine Tune knob is basically right in the middle. What I failed to realize, is that when you transmit, it is way off frequency on the other side. It will follow your Fine Tune as you move it and can tune on in so on the 2nd radio here (My Grant XL) is able to hear it find, but then now that puts everyone else while receiving the audio that far off frequency.
Another thing that is happening is that when I leave the radio alone, it will eventually just fall off and go silent. It wont come back until I transmit again and then the receive comes back for just a little bit longer before it goes away. I dont even have to move the clarifier for it to just drop out. On the Clarifier mod, it does say if that happens, then to jumper D301, and then put back the purple wire from where it was removed... The problem? I have NO idea were I even pulled it from lol. :) Been too long ago.
Even if I were to restore the wire back and jump D301, is that going to even remedy the issue of the transmit being so far off frequency? Surely there has to be a step to disable the TX adjustments inside like you usually do on other radios? There were the steps that I followed:
*****Update*********
Thanks to an awesome youtube video, the correct way to do the clarifier mod was shown, so I went ahead and posted the corrections here. Now Both receive/transmit will be on the same frequency.
Corrected CLARIFIER MODIFICATIONS for ye olde Sears Slant Face SSB:
1)Find the green wire coming off the FINE TUNING control. Follow the wire to the pc board where it connects and unsolder it.
2)Find the RED wire behind the meter display and solder the green wire form before to that location(there is 8VDC there. Don't do the red wire closest to the front, that one is 13V DC!. When in doubt, use a Multimeter to check voltages.)
3)Find the BLACK wire from the FINE TUNING control and unsolder it from the PCB. Find a ground point and solder the black wire to it.
4)Follow the Purple wire, but LEAVE the purple wire alone. This does not need to be moved. Find the one side of resistor R303 in the same area and either desolder one of the legs or clip it from the other side. The area should look something like this:
This mod will give you about 3khz up/down off the "channel".
Hoping some insight on what else needs to be done or even help on the location where that purple wire came from would help too lol. Thank you so much for reading.
Welp... Just ran into this video... Will report back if by removing one of the legs of resistor 303 will get things going the way they should.
That video had the correct information. This is how it should be:
Put the purple wire back to where it is in the picture (Its original spot), then remove the one side on R303. This corrects it so both TX/RX is the same.
Upon doing this, I learned my radio is in dire need of help. AM works, but on SSB modes, the audio slowly rolls away. It comes back for a moment after you transmit, but then leaves. Surely the 40+ years old capacitors can't be a good thing lol. Maybe save that recap job for another time. Hope this helps someone.
Reactions: TM86
,Doffo...you have a dry cap in the AGC...mine started doing that..replace the electros in the AGC and youll be golden
Ahhhh. Do you know the specific area on that board is the AGC? (In reality, I would recap the entire radio, but it isnt in the best shape cosmetically.) Maybe just to get by replacing a couple of capacitors.
let me look at my Sam's and i'm gonna have the bottom off the radio i should be able too see what i done haha..AGC recovery timinh cap...the receive takes forever to come back after unkey speshly strong stations when approaching overload...hang tight i will look after coffee
Reactions: doffo
C253 and C255 for starters...thatll likely get ya goin...you can read the location on the bottom of the board...good luck..i wired in a var. resistor to manually set it...the caps are the root problem...good luck
Reactions: doffo
  • @ Hambones amps:
