RCI SR-955HP versions?
Crambone
Well-Known Member
I Support WorldwideDX.com!
Jan 22, 2019
563
175
53
57
I picked up an SR-955HP and I’m not sure what version it is? Has the full board inside marked not the shorter one.
Reason I ask is it’s off frequency and the power control is not working properly, when I turn the power down or up it dosent drop much from full output. Also when keyed in AM with microphone gain full CCW it looks like it still has some modulation as the power fluctuates.
I tried a factory reset by holding down the 3 buttons and powering on…… but didn’t change.
So I’m in need of an Allignment procedure the software for this version.
Drew
  • @ Hambones amps:
