Anytone 5555n2 - long vs short case - One has to go :)
jrd426
Well-Known Member
I Support WorldwideDX.com!
Sep 5, 2018
280
221
53
58
hi guys, i have both the long and the "newer" short case 5555n2 radios. I dont use either much and feel i need to let one go.
Any thoughts or if its a no brainer to keep the short version opposed to the bit older and og long case n2? Both maybe have 4-5hrs of use. Not sure if the finals or other things are better between the two. as always, your opinions are appreciated. best, Jeff
Definitely keep the VFO model. I use it more than I thought I would and I would hate not having one now.
I have the long case too. It's a great backup.
  • @ Hambones amps:
