Antron 99 mounted off the side of my tower?
Jun 14, 2024
41
23
44
Just wondering if anyone has any experience mounting an Antron/Imax 2000 off the side of a tower. Without getting into the reason I need to do this, any opinions on minimum distance out from the tower for decent 10m/11m local operation in this mounting style? 2 feet...4-5 feet...more? I know a half wavelength would be "proper", but I'm just looking for any past run ins with this from anyone?
Reactions: Alexis Mercado
It might be possible to position the antenna at a height that leads to the tower section alongside it being anti-resonant by seeing what mount position leads to the least change in the R±jX sweep on an analyzer and least CMC, but that would be a trial and error nightmare. And even then, its still going to cause issues.
You could reduce (not eliminate) coupling by intentionally mounting it at an angle similar to how truckers do with tall exhaust stacks. Or maybe tune up the entire tower instead of mounting an antenna on it, but that depends on what else is on the tower.
Bad situation to be in for sure. It might be better skipping the tower and putting it on something else.
  • @ heartbreaker3473:
