Radio shack blue big stick antenna
Im wondering if I could add heavier wire and a heavier cap to the coil and what it would do. I did notice the blue RS big stick tuned differently when I replaced the rg 8x with rg 213u. I just like messing with antennas .
Adding heavier wire will slightly increase the bandwidth of the antenna, so long as the wire is the same length as the original. You can put a beefier cap with a higher voltage rating in as long as it's the same capacitance. So if there is, for example, a 500 pF cap there now, the replacement will also need to be 500 pF. It's a critical tuning component.......
Reactions: NZ8N and rogodee
Also now I know the secret of the Sirio fiberglass coaxial half wave is the coaxial RF choke at the bottom, which gives it great frequency range and isolates the feed line very well.
The Gainmaster is a 5/8ths wave center feed antenna.
I made this mistake as well years ago and at first I disregarded it as another a99 clone.
After some education, Thank you @bob85 , The DB, Marconi and others, I came to understand where the actual feed point is on the antenna.
If you search a bit here on the forum there's several threads in the CB antenna section about the Gainmaster, including a couple about building your own.
Reactions: NZ8N
This is precisely why I asked for better photos of the matching network. I have one of these, that the matching network is trashed, that I want to rebuild, bigger and better.
The one I have also has a completely corroded to nothing bonding wire at the top of the bottom section, which is what they used to connect the aluminum tube to the thread that the top connects to.
SL
Yes I know the 5/8 wave gain master, but Sirio also has fiberglass coaxial half wave antenna, that has a large coaxial RF choke at the bottom feed point to isolate the feedline.
It has a very wide frequency range for a coaxial half wave antenna.
It is basically a Big Stick with an RF choke.
My 1963 radio handbook states that coaxial antennas have the lowest radiation angle, but have a narrow frequency range.
It also describes coaxial antennas as being good at isolating the feed line, with their lower half sleeve.
The Big Stick does have a narrow frequency range, but also the feed line to a Big Stick is famous for interfering with TV reception.
Apparently the lower half sleeve is not that great for isolating the feed line, but by adding an RF choke at the feed point, Sirio has greatly increased the frequency range and isolated the feed line.
The Hygain and Radio Shack aluminum half wave antennas had three short radials near the bottom.
Hygain didn't claim these were for gain, correctly described them as expanding the frequency range, by helping isolate the feed line.
Reactions: rogodee
SL
Well if you'd be more patient ill shoot another Pic of it. Its put up and away for now. If youre going to be demanding, ill simply block you. I have a full time job, a life, a gf, and other hobbies besides radios. Just be patient...
SO.... I responded to your post, not to be demanding, but to perhaps spend some of my precious time, sharing a common interest in assisting you with your desire to increase the power handling capacity of the Crossbow stick. I have more antennas than I will ever need, it was all about the art.
You can block me now.
Reactions: 19wrc333
    boog351 has left the room.
