Parts Needed / Royce 1-641
MKwrench
Wooohoooo!!!
Aug 6, 2023
115
112
53
55
I wanted to check if anyone had a "parts" or "Broken" Royce 1-641.
I destroyed T8 in an ongoing attempt trying to extract a seized and broken cup slug.
:sick: (A slip with a sharp tool, opend the winding) :mad:
T8 and T9 are the same. I cant find a "positive" match online anywhere. Has ETC 20192 printed on it, and is listed as 02-052 (Royce P/N?), and described as an "IF 455khz" and is on page 29 of the manual I shared in the schematic. The schematic shows "3.5" near the winding in the image, but I have no clue what they are indicating.... :confused:
I Like these Royce Base radios, they look like they belong in the den or library of some old-timey mansion somewhere, surrounded by old books on a desk or shelf next to a fancy whisky decanter by the humidor.... :D
  • Royce 1641.pdf
    Royce 1641.pdf
Reactions: AudioShockwav
Not the reply you want, but I bet someone good at soldering little things could fix it if the windings are still in place and the broken ends are near each other.
I've even re-done the windings on a few IFTs and its not all that difficult if you have a good set of magnifier glasses and an old relay to source wire from~ assuming the windings are in place to count when removed.
Pretty sure that slug can be glued back together too.
Reactions: MKwrench
Hi Brandon, I gave it a whirl.
My fat arthritic fingers and eyes straining with reader glasses through a Harbor Freight lighted magnifier did their best. I had it working until it stopped & I had to press sideways on it to make it work.
I pulled it back out and reheated the connections at the pins, but now had uneven resistance from the center to each side... and then a short. I must have damaged the wire coating.
I'll try again another day.
I think the "3.5" in the schematic would be the uH value. I'm not sure if that is from 1 to 3 or from 1 to 2 and 2 to 3 ??
Check it out, I wound my 1st variable indicator. Thanks for the inspiration.
I tried to get everything I described above in pictures. "Reader glasses" ...check, "Fat arthritic fingers" ...check, "Harbor freight,cheap ass magnifier lamp" ...check....
I was so exited I made a quick video of the old Royce ticking away like nothing ever happened.
Reactions: brandon7861
I'll have to edit those other posts later....
