12 Volt Distribution
Mudfoot
Elmer
I Support WorldwideDX.com!
Jun 17, 2009
11,206
6,588
698
64
Southeast Ohio
Looking to see what people are using to bring 12 Volt power up to the dash area.
Rigrunner and power poles are to pricey, but they are nice.
I'm looking for some sort of fused/unfused distribution block with terminals to hook up 2 mobiles and maybe some misc. low draw devices. I will be bringing in at least 8-10 gauge wire from the battery with fuses near the battery. My current requirements will be under 25 amps.
I'd like to mount this block under the dash area or along the transmission hump area.
Anyways, just looking for ideas on what's out there to accomplish this task
I found a small fuse panel at a Napa Auto Parts store and wired it up to the battery with eight gauge wire. I have a CB and a rechargeable flashlight connected to it for now.
Mine looks like this.
http://javascript<b></b>:;I would use incar hifi gold plated distribution blocks combined with anderson power poles for quick release/swapping of radios/amps etc.
a few examples for you:
http://rover.ebay.com/rover/1/711-5...0001&campid=5336136228&icep_item=300562823771
XScorpion AGU Fuse Power Distribution Block 2 4 8 Gauge | eBay
STINGER SPD8124 AGU FUSED DISTRIBUTION BLOCK 4 POSITION | eBay
DIGITAL RED LED POWER DISTRIBUTION BLOCK 2/4 - 4/8 GA | eBay
Car Auto Audio Power Distribution Block AGU Fuse Holder | eBay
POWER GROUND DISTRIBUTION BLOCK DUAL 4 8 GAUGE PD12 NEW | eBay
typing agu into e bay, then selecting the sub category car electronics will find you plenty of gold plated distribution blocks/fuses. if its good enough for car hifi its good enough for radio. most are inexpensive compared to rigrunner and similar makes aimed at radio enthusiasts.
i doubt you'll find better than anderson products for high current/ quck release, i'd stick with them.
Find someone who has one of the 'PowerWerks' distribution blocks for 'power poles'. See how the things are put together (don't take it apart, whoever it belongs to will kill you). They are really not complicated, and if you were half way 'handy', I don't see why you couldn't make your own. Or design your own to fit your particular situation. I've found a cigar box and some 'handiness' can make some very usable gadgets. (Why a cigar box? Cuz that's what I had at the time.)
I'm really 'sold' on those 'PowerPoles', they work. And combined with a little imagination... ;).
