I have the MK2 version, with the PB010AB board. It doesn't have a PA jack, but the CW key jack instead.
I've tried across speaker ground to chassis ground, RX to ground, ext speaker ground to chassis, and no luck.
I plan to put it on a switch, as I only want to use it to monitor setting mic gain and such and then turn it off. IS it possible to to this?
