2 Meter J-pole
kd-5-bgt
Nov 10, 2007
1,176
93
58
Joplin Missouri area
I decided to try to make this antenna
2 Meter Jpole Calculator by dxzone.com
I have yet to set the so 239 but so far it has taken me about 2 hours to measure,cut,and solder everything.I am seeing about another hour to get it completed and check swr..Also keep in mind that I do not have the proper tools for doing this type of work and my soldering skills are very gimp at best
I know several in my area that uses this antenna and they all like it.
For those are currently looking into getting a 2 meter antenna this is an easy one to make,even for someone like me
I will post again on how the final product turned out
Several years ago i built the Super J-pole which is an extended version with an additional 1/2 wave radiator stacked on top. The bottom was 3/4 inch copper and the top part was 1/2 inch tubing. It worked VERY well until I replaced it with an 11 element yagi. Now that my rotator is broken I wish I had the Super J back up.
Super J-Pole plans
I made one too.
I went to high school with a girl named "Patina". :wub: Her father was on the Las Vegas police force, so that means he was a copper......hmmmmm.....
And don't think that little "coincidence" was lost on those of us in the LVHS Ham Club! :thumbup:
Fortunately, her last name wasn't "GREEN"! :drool:
SUCESS!!!!! :thumbup: I finally got the jpole in the air and tested on 2 meter. Under 1.5 to 1 at 146.000 and under 2 to 1 at the band edges.
The antenna is up about 35 or so feet and I am still testing for range
