2 pill high swr how long before damage ?
rizz
Feb 27, 2011
12
55
Ok I was running my amp on 10 meters stage 1 50watts, I looked ar the swr meter and it was in the red so I must of had a 4 to 5 second key down before realising there was a problem, The problem was a pl259 in the garden that had come loose on a barrel connector, my question is could I have caused any damage to the transistors running a very high swr for upto 5 seconds ?
Would,nt think so. These devices now days are very robust. If the smoke was not let out , then its all okay.
The transistors are no more robust today then they were 30 years ago. Mosfet amps are not robust at all......more like bust!!!
Reactions: 2 people
If anything poor quality control and cheap knock offs have made some of them, like decent RF transistors, somewhat less reliable today than 30 years ago. Having said that however some of the RF type MOSFETS are VERY robust and will withstand a very high SWR. The problem is that the MOSFETS used in CB or export radios are usually a switching type that just happen to work at 27 MHz and are not proper RF types at all.
Reactions: 3 people
