2950 Battery mod
Sonwatcher
3,402
26
48
Colorado
Does anyone know how to do this conversion ? I have read that you can use a 9 volt with a resistor in line with the possitive wire. Also it is said you can wire a 2 AA battery box. Where do the wire leads solder ?
Thanks,
Ron
God bless you all !
CDX-897
OT-897
WV-897
CM-2368
American Kangaroo-1897</p>
Thanks,
Ron
God bless you all !
CDX-897
OT-897
WV-897
CM-2368
Got it Done ! It was very simple once I got to the battery. Now all I have to do is change 2 AA batteries and not mess with the soldered coin cell anymore<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D">
Thanks FastEddy and Jonbah !!!
God bless you all !
CDX-897
OT-897
WV-897
CM-2368
God bless you all !
CDX-897
OT-897
WV-897
CM-2368
Hello there SonWatcher....I was wondering, what exactly does this mod due....Just curious.....73's<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/eek.gif ALT=":eek">
</p>
</p>
Phil,
It is mostly about convenience. The battery is a coin cell that has solder tabs on it and is soldered behind the face plate. It is hard to find these tabbed batteries in a store. I went to RS and bought an enclosed AA battery holder that holds 2 AA batteries with wire leads. I then bought 2 AA lithium batteries that give the 3 volts to replace the 3 volt coin cell battery. I unsoldered the coin cell and soldered the leads according to the + and - sides the old battery was soldered at. I then velcroed the box inside of the top cover so it is very neat. Now the next time I need to change the batteries all I have to do is pop a couple of AA's in instead of tearing everything down and removing the face plate to get to the battery to solder a new one in.
God bless you all !
CDX-897
OT-897
WV-897
CM-2368
Phil,
God bless you all !
CDX-897
OT-897
WV-897
CM-2368
hiya phil.on the older style 2950's the memory back-up battery was mounted on the backside of the cpu board.and
soldered in place,making replacement very difficult! doing this
mod will enable the use of cheaper batteries and simplify the
changing out of dead batteries. the original "solder/board
mount" batteries are kinda pricey and can be hard to find.
i did something similar to rons mod,but i used a solder/board mount button cell holder instead.just put some wire leads in place of battery mount and "remotely" mounted
the battery holder at the side by the chassis rail.makes a
much nicer experience changing batteries now!
no more @#^%,*%&,you lil piece of $@#%!!!!!
from the land of the worthless nut,
Slim CDX285
P.S.
good job ron! glad it went well for ya.pretty cool;musta posted
at the same time!LOL!!!
</p>Edited by: <A HREF=http://pub86.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=slimcdx285>slim cdx285</A> at: 3/2/04 11:58 am
Slim CDX285
P.S.
Boy,that's a long time Phil! I typically have to replace mine every 3-years or so.I still use the button cells,but I'm wondering if I should go w/the AA idea now? Something to
ponder 'bout!LOL !!
Slim
</p>
ponder 'bout!LOL !!
Slim
</p>
