2950dx audio problems
  • Thread starter Thread starter ftopshe
  • Start date Start date
F
ftopshe
Guest
Having receiver audio problems with my 2959dx. All of a sudden it became distorted,with a static like sound. All though still understandable,the sound quality is very poor. Tried an external speaker , no improvement. Any suggestions ? Thanks, Fred
</p>
If it starts out poor, then gets better, try the heat-gun approach... there's an electrolytic capacitor that couples A.F. to the speaker from the audio IC. Try heating it up with a heat-gun, or a blow dryer if you don't a heat gun, and the audio should clear up within seconds, if it does, replace the electrolytic, and it will come back to life. Also, if you want a higher pitched receive, use a 470uf, if you want a more "bassy" sound, you can increase it to 1000uf. Either way use at least 16WV, but over 25 volts is not needed. Hope I helped.
Take care,
Justin
</p>
If it was me, I'd click on the link at the top of the forum and send it there..... <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)">
</p>
You might also try Richard Byrd at 8541 Electronics. He did up a 2950DX for me and the price was right and the radio was great!
JD<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/pimp.gif ALT=":hat">
</p>
