4- 300z tube box
excavator701 said:
how much drive? and max pep you should see???? what would be a good driver for this amp?
Max drive for linear output (non tuned input) is about 600 watts, pep.
Tuned input, you need about 450.
Output is dependant on plate voltage, and how much current the transformer can take. But, you can figure about 900 watts PEP of linear output per tube.
If it's biased deep (as most are) then you can change those PEP numbers to "bird watts". PEP won't be much higher.
--Toll_Free
