4 loop stacked 2m chat gpt answer
nfsus
Yeah its turned off, touch it
May 9, 2011
592
315
Arkansas
I asked ChatGPT to build a high gain Omni horizontal 2 meter antenna. Here’s what I got.
Below is a detailed engineering-style construction blueprint for a 4-element stacked 2-meter halo array (144–148 MHz) commonly used by weak-signal operators for SSB, meteor scatter, and aircraft scatter.
4-Element 2-Meter Halo Array – Engineering Blueprint
Target Frequency
Design center: 144.200 MHz (typical weak-signal calling frequency).
1. Halo Loop Element Dimensions
A halo is essentially a full-wave horizontal loop with a small feed gap and a gamma match.
Loop Length Calculation
Use the full-wave formula:
L = \frac{1005}{f(\text{MHz})}
At 144.2 MHz:
L \approx 6.97 \text{ ft} \approx 83.6 \text{ inches}
Recommended construction length:
83.5 in circumference
Tubing Layout
Use 3/8-in or 1/2-in aluminum tubing.
SectionLength
Left side20.8 in
Right side20.8 in
Front20.8 in
Rear20.8 in
Feed gap1 in
Total circumference ≈ 83.2–83.6 in
Loop diameter ≈ 26–28 inches
2. Gamma Match Dimensions
Typical starting point for 2-meter halo.
ParameterValue
Gamma rod length7 in
Gamma rod diameter1/8–3/16 in aluminum
Gamma spacing from loop1 in
Series capacitor5–20 pF variable
Feed impedancetuned to 50 Ω
Gamma rod connects parallel to one side of loop.
Gamma Match Layout
Code:
Loop element
Feed gap       │
   │         Gamma rod (7 in)
              capacitor
               coax
3. Halo Stack Spacing
Spacing affects gain and takeoff angle.
Most weak-signal stations use:
Element spacingDistance
Halo 1 → Halo 240 in
Halo 2 → Halo 340 in
Halo 3 → Halo 440 in
Recommended mast:
  • Fiberglass 2–2.5 in OD
  • Non-conductive
Total height ≈ 10–11 ft
Vertical Stack Diagram
Code:
       Halo 4
      40 inches
       Halo 3
      40 inches
       Halo 2
      40 inches
       Halo 1
      Feedline
All feed gaps face same direction.
4. Phasing Harness Design
The 4 halos are fed as two phased pairs.
Code:
Top pair → combine
Bottom pair → combine
Both pairs → main feed
Electrical Length Calculations
For ¼-wave coax sections
L = \frac{246 \times VF}{f(\text{MHz})}
Where VF = velocity factor.
Phasing Harness Cut Length Table
Design frequency: 144.2 MHz
Coax TypeVelocity Factor¼ Wave½ Wave
RG-80.6611.3 in22.6 in
RG-2130.6611.3 in22.6 in
LMR-4000.8514.6 in29.2 in
Cut slightly long then trim during tuning.
Typical Harness Layout
Code:
Halo 4
¼λ coax
Halo 3
  T
½λ coax
  T
Halo 2
¼λ coax
Halo 1
5. Expected Performance
Approximate gain vs single halo.
ConfigurationGain
Single halo~2 dBi
2 halos~4 dBi
4 halos~6–7 dBi
Radiation pattern:
  • Omnidirectional horizontal
  • Low elevation angle
  • Ideal for 144 MHz weak signal
6. Materials List
Typical build:
ItemQuantity
Aluminum tubing 3/8–1/2 in28 ft
Fiberglass mast12 ft
Gamma rods4
Variable capacitors 5–20 pF4
RG-213 or LMR-400 coax~20 ft
SO-239 connectors4
Mast clamps4
7. Tuning Procedure
  1. Tune each halo individually to 144.2 MHz.
  2. Achieve SWR < 1.5:1.
  3. Assemble stack.
  4. Adjust gamma capacitor slightly.
✅ Performance tip used by EME stations
Many operators slightly increase spacing:
44–48 inches between halos
This produces slightly lower takeoff angle and ~0.3–0.5 dB more gain.
If you'd like, I can also show you:
The NASA-style antenna drawing used by serious VHF contest stations
A “super halo” design that gets 9 dB gain
A much easier 2-meter antenna that actually outperforms a 4-halo stack (most serious operators switch to it).
  • @ heartbreaker3473:
  • @ AudioShockwav:
