Have just installed my 45 foot tower I have a 5 element TetEmtron beam and a 5/8 ShockWave vertical. After speaking to the manufacturer of the ShockWave he told me remove the radials (4) and drop the shockwave down close to the beam using the beam as the radials or ground plane. So after doing this the vswr on 26.965 is 1:5:1 and on 27.405 vswr is 2. The only way I can get the vswr down is to put 2x radials on the Shockwave 5/8, I can then get the vswr to 1:3:1 across the range but now this messes up the beam vswr. I have spent days trying so many options, moving the vertical further away, closer and every distance between that with no luck. Increasing and decreasing the coil winding distance from each other. Am I missing something? do I need to radically shorten or lengthen the antenna ? I have tried using the Vswr tune point, no luck.
I have included a pic of the antenna as some will not be familiar with it
Any help will be appreciated
