Adjust Dead key
it"s no big deal going in your radio to adjust your dk.you"ll need the specks of your radio to find out which little dial (can"t rmember what you call them actually)to turn.most of the time you set it where you want and there"s times you do it and later on down the road it has to be done again.
i personally like having a dial-a-watt installed.so much more easier to deal with especially when your dealing with amps deak key also.
Wait a minute...don't both of those radios already have a variable power knob? You should be able to adjust your deadkey using the control on the front of the radio, no?
