jazzsinger,
Those 'magic' numbers are from common usage and experience. They are derived from the use of 'small' conductors for antennas and are a very general thing. Take a gander at their derivation in that Hand Book in the antenna section, it's there. Has nothing to do with copper, as such. As for rounding up/down, would you rather have it too long, or too short?
I don't particularly think looking in a handbook will change the fact that your last number is wrong.I've already told you why its wrong.
I take it you've never heard of the concepts of books being wrong or f@ckwits writing books?
Only the gullible believe what they read in one source,wise men read many sources and seek to educate themselves and question others interpretations.Once they have amassed an array of knowledge then they are in a position to make an informed judgement of facts being presented and whether or not those facts are right or wrong.
It has everything to do with copper as such,and aluminium,because they both have very similar velocity factors when air or other insulator is the dielectric surrounding them.
why not do the mathematics yourself and you will see why its wrong,infact i'll even do that for you to prove it is wrong.
300 speed of light (rounded down as you are using MHZ and not hertz as your frequency measurement) x 3.28 to convert to feet/s = 984 which gives you the number you divide your frequency by for the wavelength in feet in freespace.
984 x .95 the velocity factor of copper/aluminium in air/insulators with similar velocity factor characteristics to air = 934.8 which more often than not is rounded up to 935 or 936 for trimming,infact in most cases a bit extra is added over and above that to allow for the proximity effects of other objects.
try it with the other figures you quoted correctly and you will see they both have .95 velocity factor figured in where your last one doesn't,which makes it WRONG!!!!
I ain't one to be baffled by bull.
As for rounding up I think its particularly obvious which one I prefer,as I clearly rounded them all up to the nearest foot to allow for trimming.As its easier to trim a piece of metal/wire than it is to reattach it.
