I've read through a bunch of the posts on the site that remotely compare the AB vs C bias amps... Typically when someone mentions that ab is "cleaner" someone replies, "yes but not neccesarily... garbage in garbage out".
So lets take this scenario...
- Stock Uniden/Cobra CB (11 meter only rigs, no 10 meter, no ssb);
- Running in a stock volt application (amps are not volted - we're not in a key down competition)
- keeping final outputs within the manufacturers recommendations (not trying to squeeze 150w out of a 100w transistor).
Amps:
Texas Star 1600 V (2x8) AB-1
Dave Made 2x8 C
What would we expect to hear in terms of audio clarity/distortion?
Would there be any audible difference between the two?
How would these signals look on a scope/sa
If the goal isn't to wring every last watt out of a box, and audio/signal quality is a priority (or as much as it can be in the CB world), is there an argument for AB-1 or is a CB amp a CB amp and in this setup, little to no difference on the receiving end?
I ask because it seems to me when I here guys I know talking on C class; the audio sounds "sharper" on the edge of distortion. I know in a couple of cases they are running radio's nearly identicle to mine, but there are also a lot of other factors I'm sure. I'm the only fool in the area running AB-1 so I have no idea what my signal sounds like. I'm at a cross roads here as a bad jumper sent my sweet 16 up in smoke... one of the times I actually tried to feed it full drive and poof. Now I need to decide if I want to go back to AB or make the jump to C... for me sound on the receive as well as a clean signal on the spectrum analyzer & scope (again clean being relative here to 11 meter) are priorities...
Input?
Thanks...
Amps:
Dave Made 2x8 C
Input?
Thanks...
