alpha delta 4-b
KJ4BAE
Aug 14, 2008
50
3
18
59
I got an alpha delta 4-b switch off of e-bay, when i switch to the number 4 position it shows a dead short. I took the back plate off and it looks good. Is it supposed to do this?
I got a alpha delta (delta-4) antenna switch and all 4 positions work good. the center postition is a arc plug. i use mine backward to run more radios to one antenna though. maybe some body run to much power through the one you got. i think there rated for 1500 or 2000 watts.
I fixed it. All i did was take the arc-plug out look at it put it back in and now it works as it should. Maybe the previous owner had the plug to tight.
