alphaforce vr`s and mod limiter
fnkycoldmedina
May 18, 2005
2,266
98
58
pa
looking for any info on the vr`s inside the alphaforce am radio.i pretty much figured the important ones out but would still like to know .this radio is not covered at cb tricks.contrary to what you might think the inside of this radio is different than the deltaforce.the vr`s in the alpha(at least mine)are very small in size and marked with 3 numbers ...like 117-118.........i looked at the delta chart and it didnt compare right to this chassis.also the limiting resistor if anyone knows.and for some reason this radio and another i had (the delta)only swing 15-20 watts max...whats up with that??20 watts peak on a whistle......10-15 average talking......2 radios same thing??are others getting more??i have single final radios doing more...
