ANT help
i just made a vertical dipole...did the math for 20m an cut the wire I was gonna use for that band...trim a little off each end to get it to 1.1-1 thru the whole 20m band...NO balun and NO tuner
Yep, that will work on 20, but you will wish you had a balun when you go multiband.
